[winGRASS] gis.m error
Moritz Lennert mlennert at club.worldonline.be
Thu Nov 16 16:57:18 EST 2006
On Mon, November 13, 2006 14:44, ambiente foligno wrote:
> Startig winGrass 6.3 with gis.m the system show an error message message
> like the file in attach. (can't read "parts(n)": no such variable while
> executing "MapCanvas::zom_new$mon$parts(n).......
> so, I can use grass only in text mode. Furtermore, if I write r.in.gdal,
> I've an errore message about libpq.dll becouse there isnt' that library.
> With d.mon start=x0 i've a message like this: "no such monitor as x0.
> Problem selecting x=. Will try once more" but if i try once more is the
> same.
> Could you help me?
This means that postgresql is not installed on your system. Please also be
aware that the current version of wingrass is highly experimental and
unstable.
Moritz
More information about the grass-windows mailing list
