[GRASS-windows] Georectifier status
Moritz Lennert mlennert at club.worldonline.be
Fri Dec 14 10:19:40 EST 2007
On 14/12/07 15:59, Patton, Eric wrote:
>> No, the gis.m georectifier is a replacement of i.points /
>> i.vpoints. It should work, but I actually haven't tested it
>> yet. So if you could that would be great.
>> Moritz
> Moritz,
> Sorry to take so long getting back to you on this.
> I have a unrectified scanned map that I have imported into an XY
> location. The map has a lat-long graticule on it, so I want to
> georectify it into a lat-long location, which I have also set up.
> In the gis.m georectifier window, I have selected the PERMANENT mapset
> of my XY location in step 1, and when I try to enter the group in step
> 2, I get the error "child process exited abnormally" as soon as I click
> the 'Create/edit group' button.
> Does this module rely on any scripts that may be broken due to msys path
> abnormalities?
I can confirm the error. For the moment, you should be able to work
around it by creating the group in the xy location and then just
selecting it, thus bypassing the create/edit step.
I'll have to look into that. Unless Michael can say something about it ?
Moritz
More information about the grass-windows mailing list
