[winGRASS] Re: [GRASS-user] Re: Xganim errors in WinGRASS
yuri bay ksh_wong at msn.com
Tue Feb 6 09:52:14 EST 2007
Hi Moritz,
Thanks for the reply, could you tell me what are available in winGRASS for
the modelling and simulation of an object (e.g. a marker) movement from one
location to another on a path (e.g. a moveing vehicle) ?  Many thanks
best regards
Casey Wong
>From: Moritz Lennert <mlennert at club.worldonline.be>
>To: yuri bay <ksh_wong at msn.com>
>CC: grassuser at grass.itc.it,  wingrass at grass.itc.it
>Subject: Re: [GRASS-user] Re: Xganim errors in WinGRASS
>Date: Tue, 06 Feb 2007 15:05:03 +0100
>On 06/02/07 14:18, yuri bay wrote:
>>Hi,
>>I am trying to use the 'xganim' function (in WinGRASS) to animate a series
>>of vectors (converted from shapefiles) but has encountered the following
>>attached errors.  Any advice is much appreciated.
>AFAIK, this module is not available in WinGRASS at the moment.
>Moritz
_________________________________________________________________
Click Here To Find Your Perfect Match This Valentines!
http://msnuk.match.com/
More information about the grass-windows mailing list
