[winGRASS] Re: [GRASS-user] Re: Xganim errors in WinGRASS
Tue Feb 6 10:28:46 EST 2007
yuri bay wrote:
> I am trying to use the 'xganim' function (in WinGRASS) to animate a series
> of vectors (converted from shapefiles) but has encountered the following
> attached errors.  Any advice is much appreciated.
> couldn't execute "xganim": no such file or directory
Clearly, this component isn't included in the WinGRASS binary
packages. xganim requires Motif (it's currently the only module which
does);
Cygwin provides a package for LessTif (which should work), so there
isn't any fundamental reason why xganim can't be provided on Cygwin;
it just requires whoever builds the Cygwin packages to install LessTif
and use --with-motif when configuring GRASS.
OTOH, it isn't really an option for the native Windows (MSys) version;
the only native Motif libraries for Windows cost money.
More information about the grass-windows mailing list
