[winGRASS] Xwin error during grass62 compilation
sijan ahamed sijan4u at gmail.com
Thu Feb 15 06:54:29 EST 2007
Hi..,
When i tried to run grass62 from xwin..am getting following errors...
any help will be appreciated..
Administrator at EI_DT_50 ~
$ startx
Welcome to the XWin X Server
Vendor: The Cygwin/X Project
Release: 6.8.99.901-4
Contact: cygwin-xfree at cygwin.com
XWin was started with the following command line:
X :0 -multiwindow -clipboard
_XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
winValidateArgs - g_iNumScreens: 1 iMaxConsecutiveScreen: 1
(II) XF86Config is not supported
(II) See http://x.cygwin.com/docs/faq/cygwin-x-faq.html for more information
winDetectSupportedEngines - Windows NT/2000/XP
winDetectSupportedEngines - DirectDraw installed
winDetectSupportedEngines - DirectDraw4 installed
winDetectSupportedEngines - Returning, supported engines 00000007
winSetEngine - Multi Window or Rootless => ShadowGDI
winAdjustVideoModeShadowGDI - Using Windows display depth of 32 bits per
pixel
winAllocateFBShadowGDI - Creating DIB with width: 1024 height: 768 depth: 32
winFinishScreenInitFB - Masks: 00ff0000 0000ff00 000000ff
winInitVisualsShadowGDI - Masks 00ff0000 0000ff00 000000ff BPRGB 8 d 24 bpp
32
null screen fn ReparentWindow
null screen fn RestackWindow
InitQueue - Calling pthread_mutex_init
InitQueue - pthread_mutex_init returned
InitQueue - Calling pthread_cond_init
InitQueue - pthread_cond_init returned
winInitMultiWindowWM - Hello
winInitMultiWindowWM - Calling pthread_mutex_lock ()
winMultiWindowXMsgProc - Hello
winMultiWindowXMsgProc - Calling pthread_mutex_lock ()
MIT-SHM extension disabled due to lack of kernel support
XFree86-Bigfont extension local-client optimization disabled due to lack of
shared memory support in the kernel
(--) Setting autorepeat to delay=500, rate=31
(--) winConfigKeyboard - Layout: "00000409" (00000409)
(--) Using preset keyboard for "English (USA)" (409), type "4"
Rules = "xorg" Model = "pc105" Layout = "us" Variant = "(null)" Options =
"(null)"
(--) 3 mouse buttons found
Could not init font path element /usr/X11R6/lib/X11/fonts/CID/, removing
from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/100dpi/, removing
from list!
winPointerWarpCursor - Discarding first warp: 512 384
winInitMultiWindowWM - pthread_mutex_lock () returned.
winProcEstablishConnection - Hello
cat: /home/Administrator/.Xauthority: No such file or directory
winInitClipboard ()
winClipboardProc - Hello
DetectUnicodeSupport - Windows NT/2000/XP
winProcEstablishConnection - winInitClipboard returned.
winInitMultiWindowWM - pthread_mutex_unlock () returned.
winClipboardProc - DISPLAY=127.0.0.1:0.0
winMultiWindowXMsgProc - pthread_mutex_lock () returned.
winMultiWindowXMsgProc - pthread_mutex_unlock () returned.
winInitMultiWindowWM - DISPLAY=127.0.0.1:0.0
winMultiWindowXMsgProc - DISPLAY=127.0.0.1:0.0
winMultiWindowXMsgProc - XOpenDisplay () returned and successfully opened
the display.
winClipboardProc - XOpenDisplay () returned and successfully opened the
display.
winInitMultiWindowWM - XOpenDisplay () returned and successfully opened the
display.
winMultiWindowXMsgProcErrorHandler - ERROR: BadWindow (invalid Window
parameter)
parameter)
jaan
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20070215/7733af49/attachment.html
More information about the grass-windows mailing list
