[winGRASS] Re: missing dll's
sijan ahamed sijan4u at gmail.com
Tue Feb 20 01:51:27 EST 2007
Hi..,
Success......
After so much hard work ,i am successful to get gis manager..which was
vanishing and displaying error:"child process exited abnormally"
It was due to missing of some dll's...
 After executing cygcheck g.region ...i came to know about missing dll's
 1.libgrass_gis.6.1.cvs.dll
 2.libgrass_L.6.1.cvs.dll
I was compiling grass6.2
I have following dll's in /usr/local/grass6.2.1/lib
libgrass_gis.6.2.dll
libgrass_L.6.2.dll
i just renamed it to ...6.1.cvs.dll
And got success....
My warm thanks to Mr.glynn for helping me...
On 2/20/07, sijan ahamed <sijan4u at gmail.com> wrote:
> Sir,
> Any help will be appreciated.....
> I found out the program generating error:"child process terminated
> abnoramally"
> I followed
> "If some modules mysteriously fail there are a few things you can do
> to help diagnose the problem. If the GUI fails (for example with a
> "child process exited abnormally" error) your first check should be
> the region settings module. Try typing "g.region -p" at the command
> line and make sure you get reasonable values for north, south, east,
> west and resolution. If a module returns you to the command prompt
> with no activity at all, try typing "echo $?" immediately after to
> query the module's exit code. If that says "53" you are most likely
> missing a library (DLL). To find out which one run "cygcheck g.region"
> (replace g.region with the offending module's name). You can then
> search for the name of the package that contains the missing file at
> the Cygwin package search page. Re-run the Cywgin installer to load
> the missing package; it will have remembered your earlier selections.
> I have compiled grass62 from source code..then why it is looking for
> 6.1.cvs.dll????
> I am using
> gdal1.3.2
> cygwin 1.5.23
> proj4.4.9
> mesa-grass-6.2.1
> tiff-grass-3.7.1
> On 2/17/07, sijan ahamed <sijan4u at gmail.com> wrote:
> > Hi..,
> >   Can anyone help me??????????????????
> >  I was continously posting my probles in grass compiling..but am not
> getting
> > good support.
> >  I am successful in compiling grass62 on cygwin(winXP).
> > but while running am getting following error after entering
> mapset,location
> > through GUI
> > "grass6.2.1(demodata)~>child process exited abnormally"
> > I think it is due to problem with tcl/tk.
> > I was using packages (gcc,zlib,..) installed along with cygwin...except
> gdal
> > and proj which i compiled&installed from source code..
> > When i used Tcl/tk 8.4 package coming along with cygwin...am getting
> errors
> > in so many modules during grass compilation..
> > so I uninstalled it and just used tcl/tk libraries coming along with
> > cygwin..
> > Then i got success in compiling..then i tried installing tcl/tk from
> > cygwin..but still am getting error during running grass...
> > Should i make any linking during compiling.
> > I followed the document "install" provided with grass package.
> > Then i tried making windows binaries for grass62 on linux....But still
> didnt
> > find success...
> > ___________________________________________________________
> > I was on this mission for last 1.5 months....So expecting help..
> > Thanks in advance.................................................
> > jaan
> jaan
jaan
More information about the grass-windows mailing list
