[winGRASS] missing dll's
sijan ahamed sijan4u at gmail.com
Tue Feb 20 01:21:24 EST 2007
Sir,
Any help will be appreciated.....
I found out the program generating error:"child process terminated abnoramally"
I followed
"If some modules mysteriously fail there are a few things you can do
to help diagnose the problem. If the GUI fails (for example with a
"child process exited abnormally" error) your first check should be
the region settings module. Try typing "g.region -p" at the command
line and make sure you get reasonable values for north, south, east,
west and resolution. If a module returns you to the command prompt
with no activity at all, try typing "echo $?" immediately after to
query the module's exit code. If that says "53" you are most likely
missing a library (DLL). To find out which one run "cygcheck g.region"
(replace g.region with the offending module's name). You can then
search for the name of the package that contains the missing file at
the Cygwin package search page. Re-run the Cywgin installer to load
the missing package; it will have remembered your earlier selections.
After executing cygcheck g.region ...i came to know about missing dll's
1.libgrass_gis.6.1.cvs.dll
2.libgrass_L.6.1.cvs.dll
I have compiled grass62 from source code..then why it is looking for
6.1.cvs.dll????
I am using
gdal1.3.2
cygwin 1.5.23
proj4.4.9
mesa-grass-6.2.1
tiff-grass-3.7.1
On 2/17/07, sijan ahamed <sijan4u at gmail.com> wrote:
> Hi..,
>   Can anyone help me??????????????????
>  I was continously posting my probles in grass compiling..but am not getting
> good support.
>  I am successful in compiling grass62 on cygwin(winXP).
> but while running am getting following error after entering mapset,location
> through GUI
> "grass6.2.1(demodata)~>child process exited abnormally"
> I think it is due to problem with tcl/tk.
> I was using packages (gcc,zlib,..) installed along with cygwin...except gdal
> and proj which i compiled&installed from source code..
> When i used Tcl/tk 8.4 package coming along with cygwin...am getting errors
> in so many modules during grass compilation..
> so I uninstalled it and just used tcl/tk libraries coming along with
> cygwin..
> Then i got success in compiling..then i tried installing tcl/tk from
> cygwin..but still am getting error during running grass...
> Should i make any linking during compiling.
> I followed the document "install" provided with grass package.
> Then i tried making windows binaries for grass62 on linux....But still didnt
> find success...
> ___________________________________________________________
> I was on this mission for last 1.5 months....So expecting help..
> Thanks in advance.................................................
> jaan
jaan
More information about the grass-windows mailing list
