[winGRASS] gdal-ogr-plugin
sijan ahamed sijan4u at gmail.com
Mon Feb 19 08:15:15 EST 2007
Sir,
I hope to run d.vect filename require compilation of gdaL WITH grass
support...
so i recompiled it with following
./configure --with-grass=c:/cygwn/usr/local/grass6.2.1 \
   --with-autoload=c:/cygwin/usr/local  --with-ld-shared="g++ -shared"
make
make install
should i link dll files..if so how???Can u help me...
Hope u will reply with good solution...
any help will be appreciated
jaan
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20070219/0ffb8df3/attachment.html
More information about the grass-windows mailing list
