[winGRASS] Re: [GRASS-user] Re: Cygwin winGRASS 6.2 (Working!) and Slide Show (not working)
yuri bay ksh_wong at msn.com
Thu Feb 22 03:46:46 EST 2007
Sorry for the late reply, I am working on the animation aspect, still could
not get d.slide.show to work.
>did libpd4 and postgresql come from cygcheck DLL errors or previous
>discussion? (i.e. are they missing from setup.ini same as jasper, fftw3?)
For the previous cygwin winGRASS installation problem, I have used the
cygcheck for g.region and the DLL error is cygpg dll cannot be found.
Searching that on cygwin site gave the libpd4 and postgresql, all the
mentioned packages are missing on the initial setup.ini.
>are you using this sequence of commands?
>g.region rast=G_Newmap1
>d.mon x0
>d.slide.show prefix=G_Newmap
As for the d.slide.show, I have used the following commands provided because
I do not have a raster file:
d.mon x0
The xmon window only displayed a number of specified monitors but with
blanks, i.e. no vector graphics or any graphics displayed. My question are:
1)  Do I need to create a raster file for the slide show to work.
2) What is the usual (correct) behaviour of the d.slide.show function, i.e.
does it shows the specified vector files each at one time on each of the
specified monitors?
Many thanks in advance for your help.
Best Regards
Casey
>From: Hamish <hamish_nospam at yahoo.com>
>To: "yuri bay" <ksh_wong at msn.com>
>CC: grassuser at grass.itc.it, wingrass at grass.itc.it
>Subject: Re: [GRASS-user] Re: Cygwin winGRASS 6.2 Errors! (Working!)
>Date: Mon, 19 Feb 2007 20:30:49 +1300
>yuri bay wrote:
> > it works!
>Thanks for being our guinea pig. We've better instructions now on the
>download page for the next time someone tries.
> > So the problem is to install all the necessary stuffs, which from our
> > previous correspondences includes fftw3, jasper, openssl, libpd4 and
> > postgresql.
> > Thanks again for all your help, I will now try the network analysis
> > aspect and also the simulation animation aspects, which i think work
> > better compares to the native binary winGRASS.
>You should find everything much more settled with the UNIX version..
> > I have tried d.slide.show and the Output monitor shows the following
> > messages but without any monitors
> > Displaying vector maps....
> > G_Newmap1
> > G_Newmap2
> > G_Newmap3
> > G_Newmap* are a series of map with one point placed at a different
> > location for each G_Newmap, so that in a series they look like
> > moving. But there is  no graphic display for this process, only the
> > output string from Output monitor.
>d.mon x0
>Without an xmon the module will fail with an error before it starts.
>Does your x0 display monitor stay white? Do blank frames get drawn?
>The g.region call sets the zoom to the extent of the given raster map.
>The default region may be sitting near zero.
>Hamish
_________________________________________________________________
MSN Hotmail is evolving – check out the new Windows Live Mail
http://ideas.live.com
More information about the grass-windows mailing list
