[winGRASS] Abnormal exit
    Howard Webb
    webb.howard at gmail.com
    Fri May 18 20:15:33 EDT 2007
I have tried re-installing WinGrass several times, but haven't figured out
what part I am missing or what configuration setting I have incorrect.
WinGrass starts up just fine, and any of the menu selections work as
expected (I can load and display raster and vector maps).
However, whenever I try to run a command (i.e.: v.in.e00) from the command
window or XTerm, they fail and I get a "Exited abnormally" message.
Interestingly, I can go to the shell and run the command, though it is
giving me the error of "avce00 not found".
Has anyone experienced this, or have any suggestions?
Startup:
sh: cd: c:/mysys/1.0/bin: No such file or directory
Cleaning up temporary files.....
Starting GRASS ...
WARNING: Attention!
WARNING: Locking is not supported on Windows!
Welcome to GRASS 6.3.cvs (2006)
GRASS homepage:                          http://grass.itc.it/
This version running thru:               Bourne Shell (/bin/sh)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
If required, restart the graphical user interface with: gis.m &
When ready to quit enter:                exit
GRASS 6.3.cvs (spearfish60):C:/msys/1.0/home/Howard Webb > ~
Bat file variables:
set STARTUP_DIR=c:/mysys/1.0/bin
set PATH=%PATH%;C:\Program Files\PostgreSQL\8.2\bin;C:\MinGW\bin
set GRASS=grass
set GRASS_WISH=wish84
Thanks,
Howard
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20070518/943a09b7/attachment.html
More information about the grass-windows
