[GRASS-windows] Problems with Mapcanvas - Resolved in wingrass63RC2
Doug_Newcomb at fws.gov Doug_Newcomb at fws.gov
Mon Nov 26 16:52:47 EST 2007
I was able to sucessfully create a new mapset using EPSG codes in
winGRASS63RC2 and enter the mapset without the previous MapCanvas Error.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of Interior.
Life is too short for undocumented, proprietary data formats.
             Glynn Clements
             <glynn at gclements.
             plus.com>                                                  To
             Sent by:                  Doug_Newcomb at fws.gov
             grass-windows-bou                                          cc
             nces at lists.osgeo.         grass-dev at lists.osgeo.org,
             org                       grass-windows at lists.osgeo.org
        Subject
                                       Re: [GRASS-windows] Problems with
             11/19/2007 03:37          Mapcanvas
             PM
Doug_Newcomb at fws.gov wrote:
> > > I'm having trouble viewing any datasets on the map canvas.  When I
"Enter
> > > GRASS"  I get the following message popping up :
> > > can't read "end": no such variable
> > >     while executing
> > > "string trim $parts(projection) $end"
> > >     (procedure "MapCanvas::runprograms" line 47)
> > The code (mapcanvas.tcl:593) is:
> >                          # Finally put this into wind file format to
use with GRASS_REGION
> >                          regexp -nocase {^.* (\(.*\))}
$parts(projection) trash end
> >                          set parts(projection) [string trim
$parts(projection) $end]
> > It should be checking the return value from regexp before trying to
> > use the match variables.
>       The regions that I entered were created using the startup tool with
> the EPSG code and Georefernced file options.  Based on your feedback
below,
> I created a new mapset using qgis 0.9.  I was then able to open the new
> mapset  in GRASS without the error message.
>        Could there be a problem with the way that the startup menu
creates
> new regions/mapsets from EPSG codes and Georeferenced files?
Possibly. It would be useful to see the output from "g.region -up"
for a non-working location.
grass-windows mailing list
http://lists.osgeo.org/mailman/listinfo/grass-windows
More information about the grass-windows mailing list
