[GRASS-windows] d.profile
Markus Neteler neteler at osgeo.org
Tue Aug 19 16:08:21 EDT 2008
AFAIK most/all d.* commands are unavailable if you use native WinGrass.
With the Cygwin version, they should be available.
Markus
On Mon, Aug 18, 2008 at 6:00 PM, Louis Becker
<Louis.Becker at cellone.com.na> wrote:
> Hi
> I am trying to do a path profile in WinGrass. If I use the button in the
> monitor, I can only save an EPS file. I try to run d.profile specifying the
> raster file and a plot file, but although process is launched (found it
> under task manager), I am not able to create a path with the mouse, etc. Can
> someone help?
> Louis Becker
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
More information about the grass-windows mailing list
