[GRASS-windows] Convert from Meters to Degrees
Markus Neteler neteler at osgeo.org
Thu Aug 28 05:53:43 EDT 2008
Louis,
not sure what "Lat/Long in meters" is... can you please post the output of
gdalinfo on these maps to the list?
Markus
On Thu, Aug 28, 2008 at 11:52 AM, Louis Becker
<Louis.Becker at cellone.com.na> wrote:
> Hi
> I am fairly new to Grass and GIS in general and suspect that there is quite
> and easy answer to my question, but I have searched and searched and just
> cannot come up with a solution. Please help.
> I have a GeoTiff file that has its Lat/Long in meters. I would like to
> overlay it on a layer with Lat/Long in degrees. The rest of the
> projection/datum info is the same. If I just do a strait import, it assumes
> that the Lat/Long is in degrees and of course it is displayed in a total the
> wrong location in relation to degrees. How can I convert the file in meters
> to be projected or imported in degrees? I searched and searched, but can't
> find a solution.
> Louis Becker
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
More information about the grass-windows mailing list
