[GRASS-windows] Compiling grass7 on msys/mingw?
Moritz Lennert mlennert at club.worldonline.be
Thu Dec 18 06:51:23 EST 2008
On 18/12/08 02:21, Colin Nielsen wrote:
>> Copy in the config.guess file from the GRASS distribution.
>> CFLAGS="-O2 -s" CXXFLAGS="-O2 -s" LDFLAGS=-s ./configure
>> --prefix=/c/grass/extra
>> make
>> make install
>> (Must compile this as a static library because of obscure problems with
>> shared)
> No luck on that. I got the file (same as I had already) copied the
> config.guess from the grass_trunk folder into the xdr folder and ran
> the config line (modified to --prefix=/usr/local/ since that's where
> the other ones have been install to). make and make install seem to be
> fine:
> $ make ; make install
> make: Nothing to be done for `all'.
make clean ?
Moritz
More information about the grass-windows mailing list
