[GRASS-windows] is it possible to use R package spgrass6 to" load" MySQL data into Grass 6.3?
Moritz Lennert mlennert at club.worldonline.be
Sun Jul 20 16:36:57 EDT 2008
On 17/07/08 16:46, Darren Norris wrote:
> apologies for sending twice but first time had wrong subject line!!
> Dear all,
> I need to get data (which define vector polygons, lines and points) from
> MySQL database into GRASS (my rasters are in GRASS). As the MySQL driver
> is being worked on (but low priotity) I'm just looking for alternatives
> and advice.
Your R path seems like it should work, but if GDAL/OGR is compiled with
MySQL support then v.in.ogr should work.
Don't know which MySQL driver you are speaking about: the GRASS database
backend driver (which is irrelevant for importing spatial data from
MySQL) or the GDAL/OGR driver ?
Moritz
More information about the grass-windows mailing list
