[GRASS-windows] notes on updating GRASS via native installeronwindows vista......
Marco Pasetti marcopstt at gmail.com
Fri Jul 25 06:49:42 EDT 2008
Darren,
> well, I'm afraid about all that problems you encountered, I tried to
> "desiggn" the installer as best as possible, to let it work on both XP
> (Home and Pro) and Vista... what I can suggest you, when you run GRASS, is
> to disable the UAC; it's not a good suggestion, actually, but I can tell
> you that I needed to disable  it (I do hard jobs on my system, and I
> definetely cannot be "warned" and "asked" for permission for every low
> level task I permorm on it)... and I'm pretty happy! I also disabled the
> built-in firewall and used an external (third part) one... and all works
> fine. But there's another issue: I'm pretty sure that the UAC system
> causes other crashes or bugs on Vista (see, for example, )
sorry, I forgot the example :-) http://trac.osgeo.org/grass/ticket/118
More information about the grass-windows mailing list
