[GRASS-windows] r.los error.r. "los.exe there are encountered to problem and needs to close"
Gonzalillo9a gonzalillo9a at gmail.com
Wed Mar 12 05:03:32 EDT 2008
Hello.
I have a problem with the operation r.los in winGrass(native). I have been
testing different maps and when a distance is greater than 80-100 pixels
(map pixels) a system error is thrown.
To put an example, in spearfish data base and the elevation.dem map, grass
fails from 2524m on up  (with the height of the observer set to 1m)
The command would be:
r.los input=elevation.dem output=los coordinate=599505,4921010 max_dis=2525
The error that is reported is a system error:
"r.los.exe there are encountered to problem and needs to close"
Thanks and regards,
Gonzalo
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20080312/70c0ec99/attachment.html
More information about the grass-windows mailing list
