[GRASS-windows] Re: [GRASS-user] Xming as X server for winGRASS?
Fri Mar 14 15:19:36 EDT 2008
Moritz Lennert wrote:
> > echo %PATH% says:
> >     C:\msys\1.0\bin;C:\Perl\bin;
> > which I have set in the grass63.bat file.
> You need to add the above paths to the PATH variable, not replace all
> the contents of that variable with the above paths, i.e.
> set PATH=%PATH%;C:\msys\1.0\bin;C:\Perl\bin
I would recommend putting MSys' bin directory first, e.g.:
	set PATH=C:\msys\1.0\bin;%PATH%;C:\Perl\bin
The reason is that Windows has some programs with the same name as
common Unix programs (e.g. "find"), and scripts will want to use the
Unix versions.
More information about the grass-windows mailing list
