[GRASS-windows] Re: [GRASS-user] Xming as X server for winGRASS?
Luigi Ponti lponti at infinito.it
Sat Mar 15 08:47:13 EDT 2008
Glynn Clements wrote:
> Moritz Lennert wrote:
>>> echo %PATH% says:
>>>     C:\msys\1.0\bin;C:\Perl\bin;
>>> which I have set in the grass63.bat file.
>> You need to add the above paths to the PATH variable, not replace all
>> the contents of that variable with the above paths, i.e.
>> set PATH=%PATH%;C:\msys\1.0\bin;C:\Perl\bin
> I would recommend putting MSys' bin directory first, e.g.:
> 	set PATH=C:\msys\1.0\bin;%PATH%;C:\Perl\bin
> The reason is that Windows has some programs with the same name as
> common Unix programs (e.g. "find"), and scripts will want to use the
> Unix versions.
Thanks Glynn! I have been thinking many times how to resolve that issue:
I did not know that order would matter.
Regards,
Luigi
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20080315/c28bb545/attachment.html
More information about the grass-windows mailing list
