R: R: [GRASS-windows] GRASS 6.3.0RC5
Moritz Lennert mlennert at club.worldonline.be
Thu Mar 20 11:38:26 EDT 2008
On 20/03/08 14:45, marco.pasetti at alice.it wrote:
> Moritz,
>  >Also, before launching GRASS for the first time after re-installation
>  >erase any remaining .grassrc6 files.
> Sorry, but I don't agree: uninstall procedure automatically erase
> .grassrc6 file and the new installation creates a brand new .grassrc6
> file according to user install path;
> if you erase .grassrc6 file after re-installing GRASS, you'll miss the
> correct GISBASE configuration
Sorry, I stand corrected. I didn't know that uninstall erases the file.
Moritz
> Marco
> *Da:* Moritz Lennert [mailto:mlennert at club.worldonline.be]
> *Inviato:* gio 20/03/2008 13.50
> *A:* marco.pasetti at alice.it
> *Cc:* Markus Neteler; tabaker at u.arizona.edu;
> grass-windows at lists.osgeo.org; Michael Barton
> *Oggetto:* Re: R: [GRASS-windows] GRASS 6.3.0RC5
> On 20/03/08 12:53, marco.pasetti at alice.it wrote:
>  > Hi Moritz,
>  > I read the mail yesterday, and I checked it out immediately; all seems
>  > to work fine! I also unistalled and reinstalled winGRASS, to be sure
>  > that at a *first* launch winGRASS works fine... and it is! every time
>  > you install winGRASS installer replaces .grassrc6, so it starts with
>  > predefined location (demolocation);
>  > I tried with .bat and MSYS *launch*, and it works fine for both.
>  > Adam, could you please perform another installation of WinGRASS?
>  > uninstall the previous installation before.
> Moritz
>  > Thanks
>  > Marco
>  > *Inviato:* gio 20/03/2008 12.38
>  > *A:* Markus Neteler
>  > *Cc:* tabaker at u.arizona.edu; grass-windows at lists.osgeo.org; Michael
>  > Barton; marco.pasetti at alice.it
>  > *Oggetto:* Re: [GRASS-windows] GRASS 6.3.0RC5
>  > On 20/03/08 11:01, Markus Neteler wrote:
>  >  > On Thu, Mar 20, 2008 at 12:12 AM, Moritz Lennert
>  >  > <mlennert at club.worldonline.be> wrote:
>  >  >> On 19/03/08 23:38, Adam Baker wrote:
>  >  >>  > On Wed, Mar 19, 2008 at 3:23 PM, Moritz Lennert
>  >  >>  >> On 19/03/08 17:12, Adam Baker wrote:
>  >  >>  >>  > Hi, thanks for responding.
>  >  >>  >>  > I do have that file, C:\GRASS\tcl-tk\bin\wish.exe. When I run
>  > it a
>  >  >>  >>  > "console" and a "wish" window pop up.
>  >  >>  >>  > My grass63.bat file has a line:
>  >  >>  >>  >    set GRASS_WISH=wish.exe
>  >  >>  >>  > I made a guess and changed it to:
>  >  >>  >>  >    set GRASS_WISH=C:\GRASS\tcl-tk\bin\wish.exe
>  >  >>  >>  > That got me farther: the GRASS startup window appears.
>  > However, this
>  >  >>  >>  > message is printed to the console:
>  >  >>  >>  > access: Invalid argument
>  >  >>  >>  > ERROR: LOCATION << C:/GRASS/<UNKNOWN> >> not available
>  >  >>  >>  > And I get a Tcl-looking pop-up box that reads, "Warning:
> location
>  >  >>  >>  > <<UNKNOWN>> at GISDBASE <C:/GRASS> is not a directory or
> does not
>  >  >>  >>  > exist." When I close that, nothing seems wrong (but I wouldn't
>  >  >>  >>  > necessarily know, since this is my first interaction the
>  > program).
>  >  >>  >>  Nothing is wrong, just GRASS telling you that it doesn't have
>  > correct
>  >  >>  >>  information about a location to use, which is normal for a first
>  >  >>  >>  startup. We absolutely have to fix this as it is scary enough
>  > to make
>  >  >>  >>  people belief something is seriously wrong.
>  >  >>  >>  You should not see this message again the next time you run
> GRASS.
>  >  >>  >>  Moritz
>  >  >>  > Hi,
>  >  >>  > I did get that message multiple times, but it went away after I
>  >  >>  > changed the "GIS Data Directory" field to C:/GRASS/GIS DataBase.
>  >  >>  Yes, sorry. I meant that once you have entered grass
> successfully once
>  >  >>  and exited it again, the message should not appear anymore.
>  >  >>  > Thereafter, if I select a "Project Location" and "Accessible
> Mapset"
>  >  >>  > and then "Enter GRASS,"  I get the message "Error setting region:
>  >  >>  > child killed: unknown signal." Then another pop-up window with a
>  >  >>  > lengthy message ("can't read "parts(w)": no such variable....")
>  >  >>  > appears. Any idea about that? I can type out the whole thing if
>  >  >>  > necessary.
>  >  >>  My first guess would be that GRASS cannot find a nececssary
> library...
>  >  > The error
>  >  > is usually related to GDAL-not-found.
>  >  > Try
>  >  > g.region -p
>  >  > in GRASS to see what it says.
>  >  > This happens often, e.g.
> http://www.nabble.com/cvs---error-Ubuntu-7.10-td13859038.html#a13876447
>  >  > I don't understand why error catching on this fails again (it
> worked for
>  >  > a while!).
>  > I'm not sure it ever worked in wingrass. Another todo...
>  > Marco, could you check on this when you have the time again ? I suppose
>  > your package contains the necessary libraries ?
>  > Moritz
More information about the grass-windows mailing list
