[GRASS-windows] v.in.ogr
carranz35 carranz35 at yahoo.com
Sat Mar 22 02:50:33 EDT 2008
Hi
I am trying to display my Shapefiles in GRASS 6.3 using v.in.ogr in cmd
prompt.
This is the command
v.in.ogr -o dsn=C:/ms4w/apps/HEdRIS/data output=HEI layer=HEI
min_area=0.0001 snap=-1
I got this message.
A datum name wgs84 (WGS_1984) was specified without transformation
parameters.
Note that the GRASS default for wgs84 is towgs84=0.000,0.000,0.000.
Over-riding projection check.
Proceeding with import...
Layer: HEI
Importing map 1802 features...
Building topology ...
1802 primitives registered
Building areas:  100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids:  100%
Topology was built.
Number of nodes     :   1769
Number of primitives:   1802
Number of points    :   1802
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
GRASS 6.3.cvs (spearfish60):c:/Documents and
Settings/Kenneth.DE-EYOAA2SAFCBD >
However nothing is displayed on screen, How can I display the map?
TY
View this message in context: http://www.nabble.com/-GRASS-windows--v.in.ogr-tp16214694p16214694.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
