[GRASS-windows] v.in.ogr
Moritz Lennert mlennert at club.worldonline.be
Sat Mar 22 17:21:03 EDT 2008
v.in.ogr imports a map. To display it you have to add a layer in the
gis.m GUI and display it in the Display window.
Moritz
On 22/03/08 07:50, carranz35 wrote:
> Hi
> I am trying to display my Shapefiles in GRASS 6.3 using v.in.ogr in cmd
> prompt.
> This is the command
> v.in.ogr -o dsn=C:/ms4w/apps/HEdRIS/data output=HEI layer=HEI
> min_area=0.0001 snap=-1
> I got this message.
> A datum name wgs84 (WGS_1984) was specified without transformation
> parameters.
> Note that the GRASS default for wgs84 is towgs84=0.000,0.000,0.000.
> Over-riding projection check.
> Proceeding with import...
> Layer: HEI
> Importing map 1802 features...
> Building topology ...
> 1802 primitives registered
> Building areas:  100%
> 0 areas built
> 0 isles built
> Attaching islands:
> Attaching centroids:  100%
> Topology was built.
> Number of nodes     :   1769
> Number of primitives:   1802
> Number of points    :   1802
> Number of lines     :   0
> Number of boundaries:   0
> Number of centroids :   0
> Number of areas     :   0
> Number of isles     :   0
> GRASS 6.3.cvs (spearfish60):c:/Documents and
> Settings/Kenneth.DE-EYOAA2SAFCBD >
> However nothing is displayed on screen, How can I display the map?
> TY
More information about the grass-windows mailing list
