[GRASS-windows] Troubles with curses / Eclipse
Mon Mar 31 10:05:27 EDT 2008
"Peter Löwe" wrote:
> for a challenge, I am trying to build GRASS on a XP machine using Eclipse/CDT/msys and am stuck when it comes to Curses.
> The extra libraries were built and installed according to Marco
> Pasetti's GRASS Windows Native Binary Building Guide (great job!).
> Configure is launched with the default-settings suggested by Marco:
> <target name="configure_ziel2" description="Konfiguriere GRASS6xp">
>  <exec executable="C:\msys\1.0\bin\sh">
>  <arg value="configure" />
>  <arg value="--prefix=C:\msys\1.0\usr\local" />
>  <arg value="--with-includes=C:\msys\1.0\local\include" />
>  <arg value="--with-libs=C:\msys\1.0\usr\local\lib" />
>  <arg value="--disable-x11" />
>  <arg value="--without-jpeg" />
>  <arg value="--without-x" />
>  <arg value="--with-cxx" />
>  <arg value="--enable-shared" />
>  <arg value="--enable-largefile" />
>  <arg value="--with-opengl=windows" />
>  <arg value="--with-fftw" />
>  <arg value="--with-freetype" />
>  <arg value="--with-proj-share=C:\msys\1.0\usr\local\share\proj" />
>  <arg value="--with-gdal=C:\msys\1.0\usr\local\bin\gdal-config" />
>  <arg value="--with-tcltk" />
>  <arg value="--with-tcltk-includes=C:\msys\1.0\usr\local\tcl-tk\include" />
>  <arg value="--with-tcltk-libs=C:\msys\1.0\usr\local\tcl-tk\bin"
>  <arg value="--with-sqlite-libs=C:\msys\1.0\usr\local\sqlite\lib" />
>  <arg value="--with-postgres" />
>  <arg value="--with-postgres-includes=C:\msys\1.0\usr\local\pgsql\include"/>
>  <arg value="--with-postgres-libs=C:\msys\1.0\usr\local\pgsql\lib" />
>    </exec>
>   </target>
> Unfortunately, configure dies with the following error:
>     [exec] checking for additional include dirs... C:\msys\1.0\local\include
>      [exec] checking for additional library dirs...
>  [exec] checking curses.h WINDOW structure component... _maxy
>      [exec] checking for initscr in -lncurses... no
>      [exec] configure: error: *** Unable to locate curses library.
>      [exec] checking for initscr in -lcurses... no
>      [exec] Result: 1
> Right now I am at a loss what kind of problem i am dealing with.
> Is there a  way to compile GRASS without curses to track down the problem ?
You can use --without-curses to disable curses, but a lot of
components won't build.
The first thing to check is the config.log file. That records the
actual commands which are executed, along with any error messages
which they generate.
More information about the grass-windows mailing list
