[GRASS-windows] Re: [GRASS-dev] Updated WinGrass release installer now available
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Apr 8 22:50:29 EDT 2009
Colin,
students here are testing the new installer and everything seems to
be working fine except for nviz.
I am wondering whether the nviz version with tcltk gui is linked to
3D view instead of wxnviz?
This is on VISTA and it may be problem with local installation or
wrong region
(we will check that), but GRASS63 from Marco's installer
runs on this computer fine, including nviz.
I am wondering whether nviz runs for others.
Here is the report about the problem:
"I tried to display one elevation map.  Upon clicking 3D view, a
window pops up that says "Please
wait, loading data..."  It never gets past this point.  This action also
prevents closing GRASS.  I have to close it through the Windows Task
Manager (Ctrl-Alt-Del).  It closes with the normal method if I don't try
to bring up nviz.  "
thanks a lot,
Helena
On Apr 6, 2009, at 5:03 PM, Colin Nielsen wrote:
> I have created a new installer for grass-6.4.0RC3, built on windows
> vista (through the osgeo4w tree). This "just-double-click" installer
> creates a stand-alone Grass (no osgeo4w structure).
> This is still experimental but I think everything works (minus the old
> tcltk gui). After installation there should be two icons on your
> desktop. The "grass msys" one is new (created by me) and allows you to
> use an msys terminal with grass. Please test and report on both
> methods and on all windows versions.
> http://download.osgeo.org/grass/grass64/binary/mswindows/native/
> WinGRASS-6.4.0RC3-1-Setup.exe
> I have another installer for develbranch_6 but I'll wait to hear
> positive feedback on this one before I release it. Once a couple
> issues with 7.0 get worked out I'll put together that installer too if
> it is wanted.
> -Colin
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
More information about the grass-windows mailing list
