[GRASS-windows] Re: [GRASS-dev] Updated WinGrass release installer now available
Colin Nielsen colin.nielsen at gmail.com
Wed Apr 8 23:09:50 EDT 2009
Hi Helena,
Yes that is a problem with wingrass at the moment. I should have
mentioned that in some release notes or something. nviz and vdigit are
not working right now. I'm working on it, but I'm not getting very
far.
jef's OSGeo4W build also seems to be missing nviz support and it gives
me the same error.
Hopefully someone can help resolve this soon. Thanks for the testing.
-Colin
On Wed, Apr 8, 2009 at 10:50 PM, Helena Mitasova <hmitaso at unity.ncsu.edu> wrote:
> Colin,
> students here are testing the new installer and everything seems to be
> working fine except for nviz.
> I am wondering whether the nviz version with tcltk gui is linked to 3D view
> instead of wxnviz?
> This is on VISTA and it may be problem with local installation or wrong
> region
> (we will check that), but GRASS63 from Marco's installer
> runs on this computer fine, including nviz.
> I am wondering whether nviz runs for others.
> Here is the report about the problem:
> "I tried to display one elevation map.  Upon clicking 3D view, a window pops
> up that says "Please
> wait, loading data..."  It never gets past this point.  This action also
> prevents closing GRASS.  I have to close it through the Windows Task
> Manager (Ctrl-Alt-Del).  It closes with the normal method if I don't try
> to bring up nviz.  "
> thanks a lot,
> Helena
> On Apr 6, 2009, at 5:03 PM, Colin Nielsen wrote:
>> I have created a new installer for grass-6.4.0RC3, built on windows
>> vista (through the osgeo4w tree). This "just-double-click" installer
>> creates a stand-alone Grass (no osgeo4w structure).
>> This is still experimental but I think everything works (minus the old
>> tcltk gui). After installation there should be two icons on your
>> desktop. The "grass msys" one is new (created by me) and allows you to
>> use an msys terminal with grass. Please test and report on both
>> methods and on all windows versions.
>> http://download.osgeo.org/grass/grass64/binary/mswindows/native/WinGRASS-6.4.0RC3-1-Setup.exe
>> I have another installer for develbranch_6 but I'll wait to hear
>> positive feedback on this one before I release it. Once a couple
>> issues with 7.0 get worked out I'll put together that installer too if
>> it is wanted.
>> -Colin
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
More information about the grass-windows mailing list
