[GRASS-windows] No such file or directory
Peter Brooks peter at timedworld.com
Fri Aug 14 08:58:36 EDT 2009
Hi Markus,
 - yes it works using the GUI (should have thought to try this)
 - yes, the path contains whitespaces. Using speech or quote marks
around the full path + filename sorts it.  Falls over without. A path
without whitespace works but requires unix style forward slashes.
(I stupidly thought that by creating a mapset and saving the data
into that folder GRASS would be able to find it... didn't think I
would need the full path. Will now move the data to a c:\ncexternal
folder to reduce typing :-)
Many thanks
Peter
On 14 Aug 2009 at 13:44, Markus Neteler wrote:
On Fri, Aug 14, 2009 at 12:53 PM, Peter Brooks<peter at timedworld.com>
wrote: > Hi, I've downloaded the 'ncexternal' data from the grassbook
website - >  I created a 'ncexternal' mapset folder and copied the
files into > there. > > Whenever I try the examples that access
import
or process these files > I get an error message in GRASS. For example
on p62 > > r.in.poly in=newfacility.txt out=new_facility_1m > > gives
> > newfacility.txt: No such file or directory > > although the file
is there. I have tried adding the folder to the > Windows path, but
that doesn't solve it.
Peter - two ideas:
- does it work when you use the GUI (i.e., launch r.in.poly without
  parameters)?
- does the path to newfacility.txt contain white space? We are still
   hunting down those cases where it fails
best
Markus
More information about the grass-windows mailing list
