[GRASS-windows] No such file or directory
Peter Brooks peter at timedworld.com
Fri Aug 14 09:52:55 EDT 2009
No, I think it is whitespace...  I'm trying to use the 'cmd >' field
in the 'GRASS GIS Layer Manager' (the new wxPython GUI).  I guess
this is what a Windows user would try to do :-)
I tried adding a space to the folder name (= 'c:\nc external'),
forward slashes don't help but speech or quote marks do.
(I think the same thing happens with all r.in commands if they are
looking for external files - is this to be expected?)
Using the GRASS Command line utility (DOS shell type interface):
GRASS 6.4.0svn (North-Carolina)> cd c:/nc external
The system cannot find the path specified.
GRASS 6.4.0svn (North-Carolina)> cd c:\nc external
(works ok)
Thanks
Peter
On 14 Aug 2009 at 15:14, Markus Neteler wrote:
hi Peter,
On Fri, Aug 14, 2009 at 2:58 PM, Peter Brooks<peter at timedworld.com>
wrote: > Hi Markus, > >  - yes it works using the GUI (should have
thought to try this)
ok, good.
>  - yes, the path contains whitespaces. Using speech or quote marks
> around the full path + filename sorts it.  Falls over without. A
> path without whitespace works but requires unix style forward
> slashes.
I darkly remember that we added some Windows-magic for that
elsewhere but I don't remember how.
> (I stupidly thought that by creating a mapset and saving the data
> into that folder GRASS would be able to find it...
It does so on non-Windows and it should "learn" it also on Windows!
I tried:
GRASS 6.4.0svn (nc_spm_08): > r.in.poly in=/tmp/dd\
dd/newfacility.txt
out=new_facility_1m Writing raster map...
 100%
GRASS 6.4.0svn (nc_spm_08): > cd /tmp/dd\ dd/
GRASS 6.4.0svn (nc_spm_08):/tmp/dd dd > r.in.poly
in=./newfacility.txt
out=new_facility_1m --o Writing raster map...
 100%
Works. So it may be rather the slash stuff than white space?
> didn't think I
> would need the full path. Will now move the data to a c:\ncexternal
> folder to reduce typing :-)
Yes, for now - we hope to figure out the problem.
Please consider to open a bug report with these findings.
best
Markus
More information about the grass-windows mailing list
