Re: [GRASS-windows] Cygwin doesn´t starts
epost_jj epost.jj at gmail.com
Tue Mar 17 15:17:16 EDT 2009
Did you have a solution to this?
I get the same problem....
It opens and close within second.
Baptiste Laville wrote:
> Dear Wingrass users,
> May somebody helps me to resolve my problems with Cygwin.
> I am working with windows XP. To be able to use r.in.aster (I must import
> an .hdf file) I can´t work no more with the native Wingrass installation.
> So I try to install the Wingrass with Cygwin.
> I followed the instructions of the internet page
> http://grass.itc.it/grass63/binary/mswindows/cygwin/:
> For installation of Cygwin, see
> http://geni.ath.cx/grass.html#_Cygwin_setup_package. The instructions
> given there can be used with slight modification.
> Due to a recent change within the Cygwin installer program you must now
> start Cygwin's setup.exe from the command line as "setup.exe -X".
> At step #3 use http://grass.ibiblio.org/grass63/binary/mswindows/cygwin/
> (or a local mirror) instead of http://geni.ath.cx/grass.
> In step #5 the version is 6.3.0-2 instead of 6.0.cvs-1, and there's no
> grass.bat script.
> I downloaded the Cygwin program successfully.
> But when I try to start it, it just pop up and desappears after less then
> 0.1 sec.
> I tryed all my best and spend long long time dealing with it ...
> But now I need your help...
> Thanks really for your answers
> With my best regards
> Baptiste
> _________________________________________________________________
> News, entertainment and everything you care about at Live.com. Get it now!
> http://www.live.com/getstarted.aspx
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
View this message in context: http://n2.nabble.com/Cygwin-doesn%C2%B4t-starts-tp2170252p2493287.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
