[GRASS-windows] Re: importing ESRI grids (Enrico Crema)
Enrico R. Crema enryu_crema at yahoo.it
Fri May 1 12:20:03 EDT 2009
As I said in the previous message you should specify only the folder
with the name of the raster map and not the header-file (basically the
same thing you would do when you specify the folder in the dsn
parameter when in importing a shapefile via v.in.ogr). Does the error
still comes out doing this way?
Enrico R. Crema
Enrico R. Crema
PhD Candidate
Institute of Archaeology, UCL
AHRC Centre for the Evolution of Cultural Diversity
  +44 7899093191
http://www.cecd.ucl.ac.uk/people/?go1=91
e.crema at ucl.ac.uk
enrico.crema at gmail.com
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090501/59917ddd/attachment.html
More information about the grass-windows mailing list
