[GRASS-windows] fails on first try
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Thu May 14 10:33:28 EDT 2009
Hi Greg
Try edit
GRASS_WISH=/c/OSGeo4W/bin/wish.exe
export GRASS_WISH
grass64
or edit
/c/OSGeo4W/apps/grass/grass-6.4.0RC4/etc/Init.sh
I detected it on grass 6.4.0.RC3, for Vista, but is still was not
incorporated on recent version.
Bests
milton
2009/5/13 Hanowski, Gregory J <gregory.j.hanowski at lmco.com>
>  Hello GRASS gurus,
> Just discovered GRASS and downloaded 6.4 windows version.  Installed and
> included Spearfish sample database.  Clicked the GRASS6-SVN icon.  GRASS
> welcome screen shows.  I select project Spearfish60 and mapset PERMANENT,
> then click Start GRASS.
> I see a message for an instance about starting python.  Then an error
> message pops up: "Execution failed: 'g.proj.exe -p'.  When I click Ok to
> that, GRASS crashes and goes away.
> I also tried demolocation project and all combinations of project and
> mapset.  All failed with the same error.
> I also tried the GRASS6-SVN msys icon.  It brought up a command shell, but
> also failed with same error.  I saw some message about bad WISH environment
> variable.
> I also tried starting it in command line mode with various parameter
> combinations.  Same error.
> Not a good start.  Any ideas?
> Greg
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090514/eb9c2618/attachment.html
More information about the grass-windows mailing list
