[GRASS-windows] fails on first try
Hanowski, Gregory J gregory.j.hanowski at lmco.com
Wed May 13 20:02:47 EDT 2009
Hello GRASS gurus,
Just discovered GRASS and downloaded 6.4 windows version.  Installed and
included Spearfish sample database.  Clicked the GRASS6-SVN icon.  GRASS
welcome screen shows.  I select project Spearfish60 and mapset
PERMANENT, then click Start GRASS.
I see a message for an instance about starting python.  Then an error
message pops up: "Execution failed: 'g.proj.exe -p'.  When I click Ok to
that, GRASS crashes and goes away.
I also tried demolocation project and all combinations of project and
mapset.  All failed with the same error.
I also tried the GRASS6-SVN msys icon.  It brought up a command shell,
but also failed with same error.  I saw some message about bad WISH
environment variable.
I also tried starting it in command line mode with various parameter
combinations.  Same error.
Not a good start.  Any ideas?
Greg
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20090513/6a3cb293/attachment.html
More information about the grass-windows mailing list
