[GRASS-windows] Problem with r.thin.exe
Markus Neteler neteler at osgeo.org
Thu Nov 12 06:17:36 EST 2009
On Wed, Nov 11, 2009 at 11:03 AM, Louis Becker <Louis.Becker at leo.na> wrote:
> Hi
> When running r.thin.exe I get a WindowsXP message "r.thin.exe has encountered a problem and needs to close."  I am running Grass6.4.0SVN. Experienced the same problem on version I run before, believe it was the release just before 6.4.0SVN. Any suggestions?
Hi vista users: does r.thin work for you?
You can try it with the roads raster map of the Spearfish data set
for example.
Markus
More information about the grass-windows mailing list
