[GRASS-windows] db.execute not working
Louis Becker Louis.Becker at leo.na
Thu Oct 7 01:43:00 EDT 2010
Hi Glynn
Have tried. I get:
DBMI-SQlite driver error:
Error in sqlite3_step()
not an error
ERROR: Error while executing: 'select * from Coverage2011_4
Different error this time.
Louis Becker
Project Control Manager
T          +264 855 550 000
C          +264 855 510 136
F          +264 855 202 010
mailto:Louis.Becker at leo.na
http://www.leo.na
> -----Original Message-----
> From: Glynn Clements [mailto:glynn at gclements.plus.com]
> Sent: 07 October 2010 00:50
> To: Louis Becker
> Cc: grass-windows at lists.osgeo.org
> Subject: Re: [GRASS-windows] db.execute not working
> Louis Becker wrote:
> > I want to use db.execute in a script, but can't get it working.
> > Trying:
> > Echo "select * from Coverage2011_4" | db.execute
> In Windows' shell (cmd.exe), the quotes will be retained, causing a
> syntax error; try:
> 	Echo select * from Coverage2011_4 | db.execute
> Glynn Clements <glynn at gclements.plus.com>
DISCLAIMER
This message is intended solely for the individual(s) and entity(s) to which it is addressed.  It is confidential and may contain legally privileged information.
Any unauthorized review, use, copying, storage, disclosure or distribution of this e-mail and any attachments is strictly prohibited.  If you are not the named
recipient or have otherwise received this communication in error, please destroy this message from your system and kindly notify the sender by e-mail.
More information about the grass-windows mailing list
