[GRASS-windows] db.execute not working
Thu Oct 7 04:42:10 EDT 2010
Louis Becker wrote:
> DBMI-SQlite driver error:
> Error in sqlite3_step()
> not an error
> ERROR: Error while executing: 'select * from Coverage2011_4
I don't know if it's related, but you probably shouldn't be using
db.execute for a select statement. You would normally use db.select
for queries.
More information about the grass-windows mailing list
