[GRASS-windows] Fwd: WinGRASS installation and addtional python modules
Thu May 19 11:54:40 EDT 2011
Johannes Radinger wrote:
> Okay what I did now is to delete the python25 folder in the wingrass installation (only that folder nothing else)
> I checked the batchfile (grass64) which includes:
> call "%GISBASE%\etc\env.bat"
You should probably look at this.
> "%WINGISBASE%\etc\Init.bat" %*
And this.
> In the envvariables in windows there is no PYTHONHOME and PYTHONPATH
> is set to %GISBASE%\etc\python and GRASS_PYTHON is set to
> C:\Python27\python
I would add the ".exe" suffix to be on the safe side.
> If I try now to start winGRASS nothing happens...
> did I miss something?
You might need to have C:\Python27 in the path; I'm not sure about
that.
More information about the grass-windows mailing list
