[GRASS-windows] Fwd: WinGRASS installation and addtional python modules
Johannes Radinger JRadinger at gmx.at
Thu May 19 05:58:07 EDT 2011
-------- Original-Nachricht --------
> Datum: Thu, 19 May 2011 06:29:47 +0100
> Von: Glynn Clements <glynn at gclements.plus.com>
> An: "Johannes Radinger" <JRadinger at gmx.at>
> CC: grass-windows at lists.osgeo.org
> Betreff: Re: [GRASS-windows] Fwd: WinGRASS installation and addtional python	modules
> Johannes Radinger wrote:
> > > The WinGRASS package tries to bundle Python, which causes problems if
> > > you want to write Python scripts for GRASS. You should remove both the
> > > bundled Python and any references to it.
> > So if I understand you correctly I can do as a 6th step the removing
> > of the python2.5 which comes with winGRASS. What do you mean exactly
> > with removing, deleting the python2.5 folder in
> > programms/grass6.4.1/?
> Yes.
> > Which references have to be removed? There were no environemental
> > variables created during the winGRASS installation pointing to
> > Python25 (the winGRASS python).
> The environment variables are set in the batch file which is used to
> start GRASS.
> PYTHONHOME should not be set, and there should be no references to the
> bundled Python25 directory in PYTHONPATH or PATH.
Okay what I did now is to delete the python25 folder in the wingrass installation (only that folder nothing else)
I checked the batchfile (grass64) which includes:
@echo off
rem #########################################################################
rem #
rem # File dynamically created by NSIS installer script;
rem #
rem #
rem # GRASS Initialization
rem #
rem Set GRASS Installation Directory Variable
set GISBASE=C:\Program Files (x86)\GRASS 6.4.1
set PATH=C:\Program Files\R\R-2.12.0\bin;%PATH%
call "%GISBASE%\etc\env.bat"
"%WINGISBASE%\etc\Init.bat" %*
In the envvariables in windows there is no PYTHONHOME and PYTHONPATH is set to %GISBASE%\etc\python and GRASS_PYTHON is set to C:\Python27\python
If I try now to start winGRASS nothing happens...
did I miss something?
/johannes
NEU: FreePhone - kostenlos mobil telefonieren!
Jetzt informieren: http://www.gmx.net/de/go/freephone
More information about the grass-windows mailing list
