[GRASS-windows] Fwd: WinGRASS installation and addtional python modules
Thu May 19 01:29:47 EDT 2011
Johannes Radinger wrote:
> > The WinGRASS package tries to bundle Python, which causes problems if
> > you want to write Python scripts for GRASS. You should remove both the
> > bundled Python and any references to it.
> So if I understand you correctly I can do as a 6th step the removing
> of the python2.5 which comes with winGRASS. What do you mean exactly
> with removing, deleting the python2.5 folder in
> programms/grass6.4.1/?
Yes.
> Which references have to be removed? There were no environemental
> variables created during the winGRASS installation pointing to
> Python25 (the winGRASS python).
The environment variables are set in the batch file which is used to
start GRASS.
PYTHONHOME should not be set, and there should be no references to the
bundled Python25 directory in PYTHONPATH or PATH.
More information about the grass-windows mailing list
