[GRASS-windows] Fwd: WinGRASS installation and addtional python modules
Johannes Radinger JRadinger at gmx.at
Wed May 18 05:08:36 EDT 2011
-------- Original-Nachricht --------
> Datum: Wed, 18 May 2011 09:00:26 +0100
> Von: Glynn Clements <glynn at gclements.plus.com>
> An: "Johannes Radinger" <JRadinger at gmx.at>
> CC: grass-windows at lists.osgeo.org
> Betreff: Re: [GRASS-windows] Fwd: WinGRASS installation and addtional python	modules
> Johannes Radinger wrote:
> > Okay so what I've done now is:
> > 1) Installed Python 2.7
> > 2) Installed addtional Python modules (Numpy, Scipy, Matplotlib)
> > 3) Installed WinGRASS 6.4.1 (recent package for Windows)
> > 4) Created following environmental variables:
> >    GRASS_PYTHON C:\Python27\python
> >    PYTHONPATH  %GISBASE%\etc\python
> > 5) Restarted Windows (don't know if needed)
> > Now two questions
> > 1) Is everything done correctly
> You appear to have missed a key step.
> The WinGRASS package tries to bundle Python, which causes problems if
> you want to write Python scripts for GRASS. You should remove both the
> bundled Python and any references to it.
So if I understand you correctly I can do as a 6th step the removing of the python2.5 which comes with winGRASS. What do you mean exactly with removing, deleting the python2.5 folder in programms/grass6.4.1/?
Which references have to be removed? There were no environemental variables created during the winGRASS installation pointing to Python25 (the winGRASS python).
/johannes
> > and how can I check it (GRASS works,
> > but how to check if grass can access the python modules (Scipy)?
> > 2) Where do I have to store my python-script to call it from GRASS
> > (bin folder in the lib in Mac OS)?
> Place the script in %GISBASE%\bin. The script itself will work
> regardless of its location, but the code which generates the wxPython
> parameter dialogs requires the script to be in the path.
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
More information about the grass-windows mailing list
