[GRASS-windows] Re: Compiling WINGrass - MinGW problem
Helmut Kudrnovsky hellik at web.de
Fri Nov 4 09:43:58 EDT 2011
>What is causing the error?
please have a look in your log-file:
Started compilation: Thu Nov  3 09:00:36 CEST 2011
Errors in:
/osgeo4w/usr/src/grass-6.5.svn/lib/python
/osgeo4w/usr/src/grass-6.5.svn/gui/icons
/osgeo4w/usr/src/grass-6.5.svn/gui/images
/osgeo4w/usr/src/grass-6.5.svn/gui/wxpython/scripts
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log.  If you get an error building a library, you will
 also get errors from anything which uses the library.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Compiling-WINGrass-MinGW-problem-tp6947616p6962766.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
