[GRASS-windows] Re: Compiling WINGrass
Johannes Radinger JRadinger at gmx.at
Sun Nov 13 15:44:57 EST 2011
Hi again,
I just googled for the version of Msys which is installed
from the OsGeo4w installer...
my version of msys is 1.0.11-3 and I found:
http://sourceforge.net/project/shownotes.php?release_id=46827
So far as I understand that, comes my version of msys already with
GNU make 3.81...
So I don't understand what causes the problem then?
/Johannes
Am 13.11.2011 21:29, schrieb Johannes Radinger:
> Hi,
>>>> Johannes Radinger at JOHANNES /osgeo4w/usr/src/grass-6.5.svn/lib/python
>>>> $ make
>>>> make: *** No rule to make target `|', needed by
>>>> `/osgeo4w/usr/src/grass-6.5.svn
>>>> /dist.i686-pc-mingw32/etc/python/grass/script/core.py'.  Stop.
>> It means that you need GNU make 3.81.
>> Originally, the policy was to require 3.81 for 7.0 but ensure that 6.x
>> works with older versions. I don't know whether that policy has been
>> abandoned, or if it's just a case of careless back-porting from 7.0.
>> [CC to grass-dev for clarification; I think that we discussed this
>> fairly recently, but I don't recall the outcome.]
> I think my GNU make is the one which comes with the MSys (1.0.11-3)
> from the Osgeo4W installer.
> "MSYS is a collection of GNU utilities such as bash, make, gawk and
> grep...".
> I just followed the instructions from the GRASS wiki:
> http://trac.osgeo.org/grass/wiki/CompileOnWindows
> So I don't know which version of GNU make is bundled with that. Anyway
> if I need version
> 3.81 how do I have to proceed so that I don't destroy anything what I
> have done so far
> according to the steps in the wiki?
> What exactly do I have to download and where excactly do I have to
> install it??
> So far I just followed the instructions in the wiki, and at least the
> configure works.
> Your help is greatly appreciated!
> Thank you in advance,
> Johannes
More information about the grass-windows mailing list
