[GRASS-windows] Ordinal Not Found
miermoto deancarstens at yahoo.com
Sun Nov 27 20:22:53 EST 2011
I've done a fair bit of searching to find a solution to this issue, but with
no success.  I've installed the latest Grass and also QGIS releases, but
when I start up either of the two, I get this message:
The ordinal 53 could not be located in the dynamic link library
gssapi32.dll.
I have Python 2.5 installed and running some scripts at the moment.  I can't
stop it, because it needs to run for another week before it's finished,  but
could this be causing the problem.  Is it a python dll it's trying to
install, but fails because Python's in use?
Cheers in advance.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Ordinal-Not-Found-tp7037458p7037458.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
