[GRASS-windows] Re: Ordinal Not Found
Tue Nov 29 05:29:03 EST 2011
miermoto wrote:
> Thanks for the feedback Glynn.  I'm assuming then that it's clashing with
> other installations which also uses this DLL.  Should I just install it on a
> standalone machine or what would the workaround be?  I also run ArcGIS on
> the same machine.  It sounds like the GSSAPI covers a wider area, so it
> might be difficult to find out which app's DLL is causing the conflict.
I don't really know Windows' DLL handling well enough to know for
sure, but installing copies of all relevant DLLs in the same directory
as the executable might suffice.
Using Dependency Walker[1] may help, although it can only identify
DLLs which are linked directly, not those loaded at run-time.
[1] http://www.dependencywalker.com/
More information about the grass-windows mailing list
