[GRASS-windows] Re: Ordinal Not Found
miermoto deancarstens at yahoo.com
Sun Nov 27 23:46:09 EST 2011
Thanks for the feedback Glynn.  I'm assuming then that it's clashing with
other installations which also uses this DLL.  Should I just install it on a
standalone machine or what would the workaround be?  I also run ArcGIS on
the same machine.  It sounds like the GSSAPI covers a wider area, so it
might be difficult to find out which app's DLL is causing the conflict.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Ordinal-Not-Found-tp7037458p7037657.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
