[iTowns-user] ITowns-user Digest, Vol 7, Issue 2
Alexandre Devaux Alexandre.Devaux at ign.fr
Mon Aug 28 06:50:43 PDT 2017
Hi Nicolas!
Glad to know your interest in iTowns!
In the video the flood simulation is actually rendered on a globeView. It is an old branch you can find to test here:
https://github.com/iTowns/itowns/tree/testStatisticDataRepresentation
Zoom closely to the french coast or rivers and then click animate water and you can then move the slider for the sea level.
It works using a high res DTM in WMTS for all France. Antoine Masse (antoine.claude.masse at gmail.com) worked on it with a higher resolution DTM (created from lidar to classic grid WMTS) for french littoral also. You can specify your DTM in the WMTS_Provider.js (it's better in the last versions as you specify it in the index.html/JSON)
Then the flood was computed in the globe shaders changing the rendering depending on water depth. Another technic is to create a physical mesh for the water.
Bests!
Alexandre Devaux
Chargé d'Etudes et de Recherche
Laboratoire MATIS, IGN
Tel: 01 43 98 85 73
________________________________________
De : ITowns-user [itowns-user-bounces at lists.osgeo.org] de la part de itowns-user-request at lists.osgeo.org [itowns-user-request at lists.osgeo.org]
Date d'envoi : samedi 26 août 2017 21:00
À : itowns-user at lists.osgeo.org
Objet : ITowns-user Digest, Vol 7, Issue 2
Send ITowns-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.osgeo.org/mailman/listinfo/itowns-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        itowns-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of ITowns-user digest..."
Today's Topics:
   1. [iTownsV2] Flooding animation (Mauroy Nicolas)
Message: 1
Date: Fri, 25 Aug 2017 06:51:27 +0000
To: "itowns-user at lists.osgeo.org" <itowns-user at lists.osgeo.org>
Subject: [iTowns-user] [iTownsV2] Flooding animation
Message-ID:
        <HE1PR0101MB1755E8A29524AB18C162578D879B0 at HE1PR0101MB1755.eurprd01.prod.exchangelabs.com>
Content-Type: text/plain; charset="utf-8"
Hello,
Congratulation for the work done on this project.
I recently discovered iTowns and I am trying to play with it with some data.
I wish I can use the flooding animation I saw on the website video but I do not figure out how to use it.
-        What it is the viewer used? Planar?
-        How is build the elevation layer? What is the data format in input? Do I have to use rok4 server?
-        What should be my data format to manage the flooding animation?
Appreciate your help :)
Regards,
Nicolas
URL: <http://lists.osgeo.org/pipermail/itowns-user/attachments/20170825/18954fa4/attachment-0001.html>
Subject: Digest Footer
ITowns-user at lists.osgeo.org
End of ITowns-user Digest, Vol 7, Issue 2
More information about the ITowns-user mailing list
