[Java-collab] GDAL support on GeoTools and GeoServer
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Fri May 23 04:14:12 EDT 2008
Hi lists,
With this email we report some progresses on our work on ImageIO-EXT GDAL
geotools plugin. Main details are available at the wiki page: [1].
Briefly,
this module allows to extend the GeoTools coverage data access capabilities
by leveraging on the powerful GDAL Libraries via the ImageIO-EXT project
[2].
GeoServer will directly benefit of these improvements. You can test an
unofficial GeoServer release we have produced to test the new capabilities.
It is available at [3] as a zipped war file.
Requested extensions to be added to that GeoServer release are available at
[4]. A readme file available in this ZIP file contains instructions about
how to add extensions and where to find needed GDAL DLLs/SOs. Note that due
to licensing issues, the available dynamic libraries enable support for
MrSID, JP2K (MrSID), DTED, Erdas Imagine, NITF formats.
If you need to add support to JP2K (Kakadu) and ECW, see instructions
available at [5] (OpenOffice) or [6] (PDF), sections "GDAL Requirements" and
"GDAL Configurations" for further information on enabling ECW and Kakadu
support on GDAL. For further helps on this topic, ask questions.
Regards,
GeoSolutions
[1]: http://docs.codehaus.org/display/GEOTOOLS/ImageIO-EXT+GDAL
[2]: https://imageio-ext.dev.java.net/
[3]: http://www.geo-solutions.it/libraries/geoserver-1.7.0-SNAPSHOT-war.zip
[4]:
http://www.geo-solutions.it/libraries/geoserver-1.7.0-SNAPSHOT-imageio-ext-gdal-plugin.zip
[5]: http://www.geo-solutions.it/doc/ImageioExt-SetupGuide.odt
[6]: http://www.geo-solutions.it/doc/ImageioExt-SetupGuide.pdf
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
URL: http://lists.osgeo.org/pipermail/java-collab/attachments/20080523/ec576696/attachment.html
More information about the Java-collab mailing list
