[Fwd: Re: [Java-collab] Greetings to this list]
erwan bocher erwan.bocher at gmail.com
Fri May 23 05:17:03 EDT 2008
Hola amigo,
Hi.
> About a binary open GIS format (see below):
> I think the point is to obtain a format with quick random access (shp file
> is ok) and with the possibility to edit features (add, modify, delete)
> without writing the whole file.
> What I like from DXF is that you can use also Curves, and texts. That's why
> I mentioned it.
> Another way could be to use SQLite or H2 as local geodatabases.
You can use the H2 spatial extension available here :
http://geosysin.iict.ch/irstv-trac/browser/platform.
> About TIN, I read about this format because I need an algorithm to obtain
> contours from a TIN. ¿Do you know any java code?.
We are developing a TIN generator with hydrological functionalities
(watershed, slope, aspect, contour). Some pieces of code are available here
http://geosysin.iict.ch/irstv-trac/browser/platform/processing/src/main/java/org/gdms/triangulation/sweepLine4CDT
It's GPL 3.
Be careful, it's under development. It will be finished in some weeks maybe
2.
Kenavo
R1.
> Cheers, and very good initiative this list.
> Fran Peñarrubia.
> gvSIG team.
> Sunburned Surveyor escribió:
>> Welcome to the new mailing list Francisco!
>> You wrote: "For example, some time ago, I read a mail from Frank
>> Warmerdam about the necessity to define a good geo-format for files.
>> Maybe something simillar to .shp, but without its limitations
>> (problems to edit, lack of text support, etc). (bxml may be THE
>> solution??)"
>> I had started work on a draft schema for such a format, which you can
>> learn about here:
>> http://thejumppilotproject.pbwiki.com/Binary+Open+Feature+Format
>> BOFF defined a binary format that was meant to serve as an alternate
>> to Shapefiles. I never followed up on the spec, unfortunately. This is
>> something I should consider completing...
>> You wrote: "Or starting with a enhanced DXF, etc."
>> I'm curious what you had in mind when you talk about "enhanced DXF".
>> I'm a big user of DXF and DWG, so this is a topic I'm interested in. I
>> will note that the DXF format already supports a lot of entities that
>> we can't work with in OpenJUMP. Things like text, annotations, basic
>> blocks, external references,  and viewports come to mind.
>>  You wrote: "Not only vectorial: to push TIN formats like this:
>> http://www.vterrain.org/Implementation/Formats/ITF.html or some raster
>> formats."
>> We're working on an open source library for the creation and
>> manipulation of TINs right now as part of OpenJUMP's involvement in
>> Google Summer of Code. Right now were just working on the creation of
>> TINs from point files (CSV I think), but I know we would be interested
>> in supporting an "official" TIN format in the future.
>> Landon
>> On Tue, May 20, 2008 at 3:25 PM, Francisco José Peñarrubia
>> <fpenarru at gmail.com> wrote:
>>> Hi all.
>>> Maybe this is a good place to start some discussions that may continue in
>>> meetings and hacking events like this:
>>> http://wiki.osgeo.org/wiki/OSGeo_Hacking_event
>>> It could be interesting to define some areas to develop in common, and
>>> see
>>> how they can be useful for every Open Source project.
>>> For example, some time ago, I read a mail from Frank Warmerdam about the
>>> necessity to define a good geo-format for files. Maybe something simillar
>>> to
>>> .shp, but without its limitations (problems to edit, lack of text
>>> support,
>>> etc). (bxml may be THE solution??)
>>> Or starting with a enhanced DXF, etc. Not only vectorial: to push TIN
>>> formats like this:
>>> or some raster formats.
>>> More ideas?
>>> Cheers.
>>> Fran Peñarrubia
>>> gvSIG team.
>>> PS: I think SLD discussion is good and also useful.
>>> (http://lists.osgeo.org/pipermail/java-collab/2008-May/000001.html)
>>> PS2: I tryed "reply" to e-mail from Thunderbird and the reply goes to the
>>> sender, not to the list. Maybe the administrator of the list can change
>>> this
>>> behaviour, to reply to the list by default. (Thanks in advance)
>>> andrea antonello escribió:
>>> Hi Miguel, all,
>>> I've just joined this list, and as a member of gvSIG team, I want to show
>>> interest for this kind of collaborations.
>>> What other projects are participating in this list?
>>> I also subscribed the list as soon as I heard of it. Not exactly sure
>>> what it will be for, but following all the inter-list discussions
>>> between openjump-geotools-andsomeother, I have a good feeling about
>>> it.
>>> I'm member of the JGrass / Udig community.
>>> Cheers,
>>> Andrea
>>> Regards.
>>> Miguel Montesinos
>>> Director Técnico
>>> PRODEVELOP
>>> C/ Conde Salvatierra, 34 - 10
>>> 46004 Valencia. Spain
>>> e-mail: mmontesinos at prodevelop.es
>>> http://www.prodevelop.es
>>> Tlf: +34 963510612
>>> Java-collab mailing list
>>> Java-collab at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/java-collab
Chercheur
Docteur en géographie,
spécialité géomatique
École Centrale de Nantes
Institut de recherche en sciences et techniques de la ville
http://www.irstv.cnrs.fr/
http://geosysin.iict.ch/irstv-trac/wiki
http://r1.bocher.free.fr
http://www.projet-sigle.org
URL: http://lists.osgeo.org/pipermail/java-collab/attachments/20080523/0761f57d/attachment-0001.html
More information about the Java-collab mailing list
