[Java-collab] Simple Text Exchange Format
Andreas Schmitz schmitz at lat-lon.de
Wed May 28 03:42:59 EDT 2008
Paul Austin wrote:
> I saw in one of the other posts there was a discussion of binary format
> to replace shape files quick random access to data. Someone suggested
> using an embedded database such as H2 with a spatial extension. I think
> that using a database is a much better way to go for this kind of
> access. Otherwise if we come up with our own binary format we'll need to
> deal with all the issues such as storage management and indexing that
> databases already do for us.
I must say that I agree with Landon here (in the other post), I'd also like to
see a binary format that is more portable through languages and platforms. That
said, I'm sure that a way to store data in an embedded database has it's own
charm. Storing data in that way would also enable (more or less easy) transfer
of the data to a "real" spatial database like PostGIS (and vice versa).
> I do however think that we need a simple format for exchange of data.
> Exchanging data may be via files or via a web service. GML in my view is
> very verbose and complex to read and write and does not include an
> embedded schema.
Agreed.
> I have been working on a CSV derivative which I'm calling Enhanced-CSV.
> Basically it's a CSV file where the format is strict about placement of
> commas and use of "". It also has two header sections. The first section
> is a list of properties about the file, such as type name, projection,
> author and a list of which attribute headers will follow. The next
> header is the attribute header (schema). There can be multiple attribute
> headers including the name,type, length, precision, required flag of the
> attribute. There is one entry for each data column (attribute). Finally
> there is the data section which is just all your rows of data encoded as
> CSV. Geometries are encoded as WKT
Sounds easy and simple - I like it!
> I'm working on a specification for this format and hopefully should have
> a draft up in the next month or so. I have developed a reader and writer
> and a JUMP plug-in which I'll make available when I've finalized the
> specification.
> Is this something that would interest any one else?
Definitely. Will the reader/writer be OpenSource? Which license?
Best regards, Andreas
l a t / l o n  GmbH
Aennchenstrasse 19           53177 Bonn, Germany
phone ++49 +228 18496-12     fax ++49 +228 1849629
http://www.lat-lon.de        http://www.deegree.org
On June 17 is deegree day - Am 17. Juni ist deegree day
              http://deegree.org/deegreeday
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/java-collab/attachments/20080528/d3e4ebf8/attachment-0001.bin
More information about the Java-collab mailing list
