[Java-collab] Simple Text Exchange Format
Francisco José Peñarrubia fjp at scolab.es
Wed May 28 03:58:40 EDT 2008
Hi.
About this format, I would recommend some suggestions:
1.- Take care about encoding.
2.- At least, set a default date / time format or specify also in header.
3.- If you include an index file (for example, longs with the position
in file where each record starts, it may allow you to spatially index
the file, random access and edit each record without rewriting the whole
file. Even to set a order (to put a feature below other, for example).
About metadata, I think it will be better an already existent format,
but I'm not sure. And maybe a good idea would be to allow distribution
of those files in .zip file.
Thanks for your formats, Paul and Landon. Good to see people with this
kind of interests here.
PS: Anyone has compared SQLite and H2?. (Spatial)
Fran.
gvSIG team.
Paul Austin escribió:
> All,
> I saw in one of the other posts there was a discussion of binary
> format to replace shape files quick random access to data. Someone
> suggested using an embedded database such as H2 with a spatial
> extension. I think that using a database is a much better way to go
> for this kind of access. Otherwise if we come up with our own binary
> format we'll need to deal with all the issues such as storage
> management and indexing that databases already do for us.
> I do however think that we need a simple format for exchange of data.
> Exchanging data may be via files or via a web service. GML in my view
> is very verbose and complex to read and write and does not include an
> embedded schema.
> I have been working on a CSV derivative which I'm calling
> Enhanced-CSV. Basically it's a CSV file where the format is strict
> about placement of commas and use of "". It also has two header
> sections. The first section is a list of properties about the file,
> such as type name, projection, author and a list of which attribute
> headers will follow. The next header is the attribute header (schema).
> There can be multiple attribute headers including the name,type,
> length, precision, required flag of the attribute. There is one entry
> for each data column (attribute). Finally there is the data section
> which is just all your rows of data encoded as CSV. Geometries are
> encoded as WKT
> Below is a sample of a ECSV file with the three sections.
> {http://ns.ecsv.org/ecsv}typeName,QName,{GFT}GFT_CAPTURE_METHOD_CODE
> {http://ns.ecsv.org/ecsv}srid,QName,{http://epsg.org}3005
> {http://ns.ecsv.org/ecsv}attributeHeaderTypes,list,"{http://ns.ecsv.org/ecsv}attributeName,{http://ns.ecsv.org/ecsv}attributeType,{http://ns.ecsv.org/ecsv}attributeLength,{http://ns.ecsv.org/ecsv}attributeScale,{http://ns.ecsv.org/ecsv}attributeRequired"
> CAPTURE_METHOD_CODE_ID,CODE_VALUE,WHO_CREATED,WHEN_CREATED
> integer,string,string,dateTime
> 3,255,255,2147483647
> 0,0,0,0
> false,false,false,false
> 1,Photogrammetric,PROXY_GFT,2008-05-26T00:00:00
> 2,Differential Gps,PROXY_GFT,2008-05-26T00:00:00
> 3,Tablet Digitizing,PROXY_GFT,2008-05-26T00:00:00
> I'm working on a specification for this format and hopefully should
> have a draft up in the next month or so. I have developed a reader and
> writer and a JUMP plug-in which I'll make available when I've
> finalized the specification.
> Is this something that would interest any one else?
> Paul
> Java-collab mailing list
> Java-collab at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/java-collab
More information about the Java-collab mailing list
