[Liblas-commits] laszip: 2 new changesets
    liblas-commits at liblas.org
    Mon Dec 13 23:12:22 EST 2010
changeset bd3dd914ed48 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=bd3dd914ed48
summary: move win32 DEPRECATE stuff into CMake
changeset aa2026d10a92 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=aa2026d10a92
summary: sync w/ Martin's changes
diffstat:
 CMakeLists.txt     |   204 +++++----
 src/CMakeLists.txt |   172 +++----
 tools/lasdiff.cpp  |  1096 +++++++++++++++++++++++++--------------------------
 tools/laszip.cpp   |   866 ++++++++++++++++++++--------------------
 4 files changed, 1159 insertions(+), 1179 deletions(-)
diffs (truncated from 2358 to 300 lines):
diff -r be0f660c109b -r aa2026d10a92 CMakeLists.txt
--- a/CMakeLists.txt	Mon Dec 13 18:19:41 2010 -0800
+++ b/CMakeLists.txt	Mon Dec 13 20:09:36 2010 -0800
@@ -1,96 +1,110 @@
-# Main CMake configuration file for laszip
-# Author: Mateusz Loskot <mateusz at loskot.net>
-# laszip general settings
-project(laszip)
-# Name of C++ library
-set(LASZIP_LIB_NAME liblaszip)
-set(CMAKE_INCLUDE_DIRECTORIES_PROJECT_BEFORE ON)
-# CMake settings
-cmake_minimum_required(VERSION 2.6.0)
-set(CMAKE_COLOR_MAKEFILE ON)
-# Allow advanced users to generate Makefiles printing detailed commands
-mark_as_advanced(CLEAR CMAKE_VERBOSE_MAKEFILE )
-# Path to additional CMake modules
-set(CMAKE_MODULE_PATH ${laszip_SOURCE_DIR}/cmake/modules ${CMAKE_MODULE_PATH})
-# General build settings
-# Default to release mode
-if(NOT MSVC_IDE)
-  set(CMAKE_BUILD_TYPE Release CACHE STRING
-    "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel")
-endif()
-# TODO: Still testing the output paths --mloskot
-set(LASZIP_BUILD_OUTPUT_DIRECTORY ${PROJECT_BINARY_DIR}/bin/${CMAKE_BUILD_TYPE})
-# Output directory in which to build RUNTIME target files.
-set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${LASZIP_BUILD_OUTPUT_DIRECTORY})
-# Output directory in which to build LIBRARY target files
-set(CMAKE_LIBRARY_OUTPUT_DIRECTORY ${LASZIP_BUILD_OUTPUT_DIRECTORY})
-# Output directory in which to build ARCHIVE target files.
-set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY ${LASZIP_BUILD_OUTPUT_DIRECTORY})
-# Installation settings
-if(WIN32)
-  set(DEFAULT_LIB_SUBDIR lib)
-  set(DEFAULT_DATA_SUBDIR .)
-  set(DEFAULT_INCLUDE_SUBDIR include)
-  if (MSVC)
-    set(DEFAULT_BIN_SUBDIR bin)
-  else()
-    set(DEFAULT_BIN_SUBDIR .)
-  endif()
-else()
-  # Common locations for Unix and Mac OS X
-endif()
-# Locations are changeable by user to customize layout of laszip installation
-# (default values are platform-specific)
-set(LASZIP_BIN_SUBDIR ${DEFAULT_BIN_SUBDIR} CACHE STRING
-  "Subdirectory where executables will be installed")
-set(LASZIP_LIB_SUBDIR ${DEFAULT_LIB_SUBDIR} CACHE STRING
-  "Subdirectory where libraries will be installed")
-set(LASZIP_INCLUDE_SUBDIR ${DEFAULT_INCLUDE_SUBDIR} CACHE STRING
-  "Subdirectory where header files will be installed")
-set(LASZIP_DATA_SUBDIR ${DEFAULT_DATA_SUBDIR} CACHE STRING
-  "Subdirectory where data will be installed")
-# Mark *_SUBDIR variables as advanced and dedicated to use by power-users only.
-mark_as_advanced(LASZIP_BIN_SUBDIR
-  LASZIP_LIB_SUBDIR LASZIP_INCLUDE_SUBDIR LASZIP_DATA_SUBDIR)
-# Full paths for the installation
-set(LASZIP_BIN_DIR ${LASZIP_BIN_SUBDIR})
-set(LASZIP_LIB_DIR ${LASZIP_LIB_SUBDIR})
-set(LASZIP_INCLUDE_DIR ${LASZIP_INCLUDE_SUBDIR})
-set(LASZIP_DATA_DIR ${LASZIP_DATA_SUBDIR})
-# Processing of project directories
-add_subdirectory(src)
+# Main CMake configuration file for laszip
+# Author: Mateusz Loskot <mateusz at loskot.net>
+# laszip general settings
+project(laszip)
+# Name of C++ library
+set(LASZIP_LIB_NAME liblaszip)
+set(CMAKE_INCLUDE_DIRECTORIES_PROJECT_BEFORE ON)
+# CMake settings
+cmake_minimum_required(VERSION 2.6.0)
+set(CMAKE_COLOR_MAKEFILE ON)
+# Allow advanced users to generate Makefiles printing detailed commands
+mark_as_advanced(CLEAR CMAKE_VERBOSE_MAKEFILE )
+# Path to additional CMake modules
+set(CMAKE_MODULE_PATH ${laszip_SOURCE_DIR}/cmake/modules ${CMAKE_MODULE_PATH})
+# General build settings
+# Default to release mode
+if(NOT MSVC_IDE)
+  set(CMAKE_BUILD_TYPE Release CACHE STRING
+    "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel")
+endif()
+# TODO: Still testing the output paths --mloskot
+set(LASZIP_BUILD_OUTPUT_DIRECTORY ${PROJECT_BINARY_DIR}/bin/${CMAKE_BUILD_TYPE})
+# Output directory in which to build RUNTIME target files.
+set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${LASZIP_BUILD_OUTPUT_DIRECTORY})
+# Output directory in which to build LIBRARY target files
+set(CMAKE_LIBRARY_OUTPUT_DIRECTORY ${LASZIP_BUILD_OUTPUT_DIRECTORY})
+# Output directory in which to build ARCHIVE target files.
+set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY ${LASZIP_BUILD_OUTPUT_DIRECTORY})
+# Platform and compiler specific settings
+if(WIN32)
+  if (MSVC)
+    if (MSVC80 OR MSVC90 OR MSVC10)
+      add_definitions(-D_CRT_SECURE_NO_DEPRECATE)
+      add_definitions(-D_CRT_SECURE_NO_WARNINGS)
+      add_definitions(-D_CRT_NONSTDC_NO_WARNING)
+      add_definitions(-D_SCL_SECURE_NO_WARNINGS)
+    endif()
+  endif()
+endif()
+# Installation settings
+if(WIN32)
+  set(DEFAULT_LIB_SUBDIR lib)
+  set(DEFAULT_DATA_SUBDIR .)
+  set(DEFAULT_INCLUDE_SUBDIR include)
+  if (MSVC)
+    set(DEFAULT_BIN_SUBDIR bin)
+  else()
+    set(DEFAULT_BIN_SUBDIR .)
+  endif()
+else()
+  # Common locations for Unix and Mac OS X
+endif()
+# Locations are changeable by user to customize layout of laszip installation
+# (default values are platform-specific)
+set(LASZIP_BIN_SUBDIR ${DEFAULT_BIN_SUBDIR} CACHE STRING
+  "Subdirectory where executables will be installed")
+set(LASZIP_LIB_SUBDIR ${DEFAULT_LIB_SUBDIR} CACHE STRING
+  "Subdirectory where libraries will be installed")
+set(LASZIP_INCLUDE_SUBDIR ${DEFAULT_INCLUDE_SUBDIR} CACHE STRING
+  "Subdirectory where header files will be installed")
+set(LASZIP_DATA_SUBDIR ${DEFAULT_DATA_SUBDIR} CACHE STRING
+  "Subdirectory where data will be installed")
+# Mark *_SUBDIR variables as advanced and dedicated to use by power-users only.
+mark_as_advanced(LASZIP_BIN_SUBDIR
+  LASZIP_LIB_SUBDIR LASZIP_INCLUDE_SUBDIR LASZIP_DATA_SUBDIR)
+# Full paths for the installation
+set(LASZIP_BIN_DIR ${LASZIP_BIN_SUBDIR})
+set(LASZIP_LIB_DIR ${LASZIP_LIB_SUBDIR})
+set(LASZIP_INCLUDE_DIR ${LASZIP_INCLUDE_SUBDIR})
+set(LASZIP_DATA_DIR ${LASZIP_DATA_SUBDIR})
+# Processing of project directories
+add_subdirectory(src)
 add_subdirectory(tools)
\ No newline at end of file
diff -r be0f660c109b -r aa2026d10a92 src/CMakeLists.txt
--- a/src/CMakeLists.txt	Mon Dec 13 18:19:41 2010 -0800
+++ b/src/CMakeLists.txt	Mon Dec 13 20:09:36 2010 -0800
@@ -1,100 +1,74 @@
-# src/CMakeLists.txt controls building of laszip library
-# Copyright (c) 2009 Mateusz Loskot <mateusz at loskot.net>
-set(LASZIP_HEADERS_DIR ../include/laszip)
-set(LASZIP_HPP
-  ${LASZIP_HEADERS_DIR}/lasdefinitions.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter0compressed.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter0compressedarithmetic.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader0compressed.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter0raw.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader0compressedarithmetic.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter1compressed.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader0raw.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter1compressedarithmetic.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader1compressed.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter1raw.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader1compressedarithmetic.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter2compressed.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader1raw.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter2compressedarithmetic.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader2compressed.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter2raw.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader2compressedarithmetic.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter3compressed.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader2raw.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter3compressedarithmetic.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader3compressed.hpp
-  ${LASZIP_HEADERS_DIR}/laspointwriter3raw.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader3compressedarithmetic.hpp
-  ${LASZIP_HEADERS_DIR}/lasreader.hpp
-  ${LASZIP_HEADERS_DIR}/laspointreader3raw.hpp
-  ${LASZIP_HEADERS_DIR}/laswriter.hpp
-  ${LASZIP_HEADERS_DIR}/liblaszip.hpp
-set(LASZIP_CPP
-    arithmeticdecoder.cpp
-    laspointwriter0compressedarithmetic.cpp
-    arithmeticencoder.cpp
-    laspointwriter1compressed.cpp
-    arithmeticintegercompressor.cpp
-    laspointwriter1compressedarithmetic.cpp
-    arithmeticmodel.cpp
-    laspointwriter2compressed.cpp
-    laspointreader0compressed.cpp
-    laspointwriter2compressedarithmetic.cpp
-    laspointreader0compressedarithmetic.cpp
-    laspointwriter3compressed.cpp
-    laspointreader1compressed.cpp
-    laspointwriter3compressedarithmetic.cpp
-    laspointreader1compressedarithmetic.cpp
-    lasreader.cpp
-    laspointreader2compressed.cpp
-    laswriter.cpp
-    laspointreader2compressedarithmetic.cpp
-    rangedecoder.cpp
-    laspointreader3compressed.cpp
-    rangeencoder.cpp
-    laspointreader3compressedarithmetic.cpp
-    rangeintegercompressor.cpp
-    laspointwriter0compressed.cpp
-    rangemodel.cpp
-    liblaszip.cpp
-set(LASZIP_SOURCES
-  ${LASZIP_HPP}
-  ${LASZIP_CPP}
-# Group source files for IDE source explorers (e.g. Visual Studio)
-source_group("CMake Files" FILES CMakeLists.txt)
-source_group("Header Files" FILES ${LASZIP_HPP})
-source_group("Source Files" FILES ${LASZIP_CPP})
-# Standard include directory of laszip library
-include_directories(../include ../include/laszip .)
More information about the Liblas-commits
