[Liblas-commits] laszip: missing header file
    liblas-commits at liblas.org
    Tue Dec 14 06:38:53 EST 2010
changeset abac5891d7de in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=abac5891d7de
summary: missing header file
diffstat:
 src/mydefs.hpp |  85 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
 1 files changed, 85 insertions(+), 0 deletions(-)
diffs (89 lines):
diff -r be0f660c109b -r abac5891d7de src/mydefs.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/src/mydefs.hpp	Tue Dec 14 03:36:54 2010 -0800
@@ -0,0 +1,85 @@
+ * Project:  integrating laszip into liblas - http://liblas.org -
+ * Purpose:
+ * Author:   Martin Isenburg
+ *           isenburg at cs.unc.edu
+ * Copyright (c) 2010, Martin Isenburg
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef MYDEFS_H
+#define MYDEFS_H
+typedef int                I32;
+typedef short              I16;
+typedef signed char        I8;
+typedef unsigned int       U32;
+typedef unsigned short     U16;
+typedef unsigned char      U8;
+#if defined(WIN32)            // 64 byte integer under Windows
+typedef unsigned __int64   U64;
+typedef __int64            I64;
+#else                          // 64 byte integer elsewhere ...
+typedef unsigned long long U64;
+typedef long long          I64;
+#endif
+typedef float              F32;
+typedef double             F64;
+typedef bool               BOOL;
+typedef union U32F32 { U32 u32; F32 f32; } U32F32;
+typedef union U64F64 { U64 u64; F64 f64; } U64F64;
+typedef union I32F32 { I32 i32; F32 f32; } I32F32;
+typedef union I64F64 { I64 i64; F64 f64; } I64F64;
+#define F32_MAX            +1.0e+30f
+#define F32_MIN            -1.0e+30f
+#define U8_MAX             0xFF // 255
+#define U8_MAX_PLUS_ONE    0x0100 // 256
+#define U16_MAX            0xFFFF // 65535
+#define U16_MAX_PLUS_ONE   0x00010000 // 65536
+#define U32_MAX            0xFFFFFFFF // 4294967295
+#if defined(WIN32)            // 64 byte unsigned int constant under Windows
+#define U32_MAX_PLUS_ONE   0x0000000100000000 // 4294967296
+#else                         // 64 byte unsigned int constant elsewhere ...
+#define U32_MAX_PLUS_ONE   0x0000000100000000ull // 4294967296
+#endif
+#define I8_MIN             0x80 // -128
+#define I8_MAX             0x7F // 127
+#define I16_MIN            0x8000 // -32768
+#define I16_MAX            0x7FFF // 32767
+#define I32_MIN            0x80000000 // -2147483648
+#define I32_MAX            0x7FFFFFFF //  2147483647
+#ifndef FALSE
+#define FALSE   0
+#endif
+#ifndef TRUE
+#define TRUE    1
+#endif
+#ifndef NULL
+#define NULL    0
+#endif
+#endif
More information about the Liblas-commits
